Banjo Fittings
Clonebug
Banjo Fittings
Post by Clonebug »
I have been searching online for a 12 mm Banjo with a 8 mm or 5/16ths inch hose barb and have not had much luck.
Has anyone run across a website that carries them for a reasonable price??
I have found a couple but they are $18.00-24.00 which is a bit unseasonable to me.
Clonebug
Re: Banjo Fittings
Post by Clonebug »
Wouldn't you know it ....after stewing for a couple weeks and looking high and low on the internet for a fitting I go over to my brothers house to pick up a drill bit and low and behold.......he is working on a Honduh and had to replace a fuel line that had a 12 millimeter banjo on each end.......WOOT.
It has crimped ends like a hydraulic hose ...so I cut one off and it will work just perfectly with my FI 5/16 hose and a FI clamp. The other one might even be better due to the 90 degree bend it has that will allow me to route the hose a little easier too!!!!
andy198712
Re: Banjo Fittings
Post by andy198712 »
i love a free fix!
Devastator
Re: Banjo Fittings
Post by Devastator »
Sucks for your brother's Honduh. :)
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
Dale M.
Re: Banjo Fittings
Post by Dale M. »
Here are some.... So you don't have to raid neighbors or strangers Honduh...
http://www.summitracing.com/search?keyw ... ings&dds=1
Dale
Clonebug
Re: Banjo Fittings
Post by Clonebug »
Dale M. wrote:Here are some.... So you don't have to raid neighbors or strangers Honduh...
Dale
I've been there and none have a 12 mm banjo with a 5/16ths hose barb. :wink:
Clonebug
Re: Banjo Fittings
Post by Clonebug »
Devastator wrote:Sucks for your brother's Honduh. :)
Not my brother's Honduh....but one of his 10 kid's friends that he was working on an engine swap since they threw a rod out the side of the block on the original. :wink:
My brother comes from old school....Big block LS6 '70 chevelle that he sold and he now has a chipped 05 Subaru STI that is scary to drive....350 hp mad machine.... :shock:
Scares the heck out of me... :wink: :lol:
Dale M.
Re: Banjo Fittings
Post by Dale M. »
How about.... IDA's are 12mm if I remember correctly.... Do not know what size threads are but a phone call or e-mail could probably provide details...
http://www.piercemanifolds.com/product_p/670014.htm....
Or double....
http://www.piercemanifolds.com/product_p/670015.htm
And possibly find screw in barb to match thread in "fuel block"...
This should be pretty close...
https://www.belmetric.com/bnjf1278-banj ... 14_850_852
8 mm = 0.314 inches and 5/16 is 0.3125 inches....
OR may be....
https://www.belmetric.com/index.php?mai ... o=&x=0&y=0
Dale
