80-83 Vanagon Injector Upgrade: 0-280-150-114
Posted: Sun Feb 24, 2013 7:47 am
by luftvagon
Does anyone know is there are any other Bosch top fed low or high impedance injectors that would fit into Vanagon intake ports?
Ratwell has a nice list http://www.ratwell.com/technical/Injectors.html but these are all stock volume injectors. I am looking for a big bump in cc/min.
I'm interested in physical dimension correctness since this is not going to be used with L-Jetronic.
Re: 80-83 Vanagon Injector Upgrade: 0-280-150-114
Posted: Tue Feb 26, 2013 4:59 pm
by Jadewombat
The physical dimensions are all pretty much the same of the Bosch injectors. I used L-jet ones, Jetta VR6, and now some from a Ford on my bus with Mexican end castings and the seal around the mid-section and the tip was the same size for all three.
The Jetta VR6 ones I think were 230cc or something.
*Edit, sorry I just looked back and you asked about low impedance. Do a search with "Bosch 0 280 injector" there's ton of directories out there*
Posted: Wed Feb 27, 2013 8:18 pm
by luftvagon
High or low impedance is fine... So any 0-280-injector would work?
Posted: Thu Feb 28, 2013 6:39 am
by Jadewombat
The physical dimensions are the same externally, the flow internally is different. Why do you need low impedance though?
Posted: Thu Feb 28, 2013 7:34 am
by luftvagon
I don't really need low impedance.. The length and physical size is the only thing that I worry about... I'm hoping I can find these injectors for ~$20/pop new/non refurbished. The cheapest 0-280-150-114 I found is $41 from Standard MP (SMP) sold under various brands. It's either original Bosch ($160/pop) or SMP made (various variations on the model)...
Posted: Thu Feb 28, 2013 10:16 am
by risk
Aircooled.net has them rebuilt and matched..
http://vwparts.aircooled.net/Fuel-Injec ... 50-114.htm
Or there are several places online that will rebuild yours and flow match them.. does your parts motor have injectors? You could send those off to rebuild..
Posted: Sun Mar 03, 2013 7:27 pm
by luftvagon
0280150206 is probably the best way to go.. that way i remove the L-Jet resistors out of the equation, and retain stock flow..
Stock CV 1970cc Type4 with 42x36 valves and Hydraulic cam.
objections?
Posted: Fri Mar 08, 2013 8:47 am
by luftvagon
I really wanted the GP Sorensen Injector 800-1206N (disc type), but the AutoZone dropped the ball. They said they cant order these anymore, even though they list them on their site. I had other compatible injectors next-dayed free of charge from their competitor...
Say hello to BWD 57530:
http://i.imgur.com/2p5bMkM.jpg
