I want to use my mill to drill holes in blank drums and rotors. I would also like to cut off the excess material on some old drums to use as hubs. I was thinking that I could use a rotating table for that, but I am uncertain how to mount them to the table on center. I do not have a table yet. Would a flat table that the work material has to be clamped to be better or would one with a chuck be more suitable? Could a chuck hold the drums/rotors from the inside of the bore to center them?
Thank you
Milling Tools for Drums and Rotors
- ProctorSilex
Re: Milling Tools for Drums and Rotors
As long as it was set up correctly I don't see why it shouldn't work. I'd be perfectly sure by maybe doing a test piece first before you chance something expensive trying it out.
