74 sold
sassmatt72
74 sold
Post by sassmatt72 »
74 superbug
sold
sassmatt72
Re: 74 (no smog) super awesome ride, tons of power and grip
sorry, details for stf people,
MS3 with relay board, vac signal air intake temp tps crank position, Innovations wide-band, 33 in/lbs injectors, 36/1 crank sensor, wasted spark driven by ms3 no edis module, vacuum driven fuel reg, cb performance intake castings w/ new type injector clamps, single TB (ford) w/ tps, (has air idle control valve too but removed as unneeded in this tune) all controlled by PWM and spark timing, ATL fuel cell in spare location with fuel shut-off solenoid and roll-over switch, car also has full standalone vdo gauge system.
Ms and relay are inside car in rear package area, with OG vw electrical box in engine bay for fuses
this car is tight, full ground up re-build a few years ago, I've driven her for a while and she's been very reliable for me.
andrew peterson did MS tuning (of Hot Rod magazine's engine builders challenge) and final be-bugging.
I've been driving her regularly for over a year now. but it's time for a sprinter van
sassmatt72
my super should be on display at bug-o-ramma Sacramento, unless it's sold before then. thanks, all m
