We sell real Weber Carburetors that are made in Spain. Unless you special order vintage Weber carburetors from us which be made elsewhere.
http://www.DirtyRacingAndRods.com
READY TO RUN
2) 40 IDF Weber Carburetors, Authentic and Made In Spain
(2) Aluminum Manifolds
(1) Throttle Linkage Assembly
(2) K&N Style Filter Assembly W/ Chrome Lids
(1) Instructions for Installation
Several Feet of Fuel Hose & Miscellaneous Installation Pieces
The two-barrel 40/44/48mm IDF, is one of the more popular Weber carburetors. IDF carburetors are available from with either 40, 44, or 48mm bore and throttle plate diameter; the "IDF" suffix indicates that this is a high performance downdraft carburetor.
The IDF carburetor design is simple yet elegant, with no metering rods, power valves, rubber seals or plastic parts. Its features a diaphragm-style accelerator pump and brass floats. The throttle shaft rides in precision roller bearings. Weber 40/44/48 IDFs can be tuned to work with nearly any displacement or compression ratio by virtue of interchangeable venturi that permit them to be tuned to flow as much (or as little) CFM as your engine requires. Tuned IDFs offer superb torque and a smooth horsepower curve, which makes them especially well suited to street use.
http://www.DirtyRacingAndRods.com (760)670-6165
