Orange Peel? Need help
cvbug
Hello this is my first post and need some help. I am preping my 68 bug for paint by priming and blocking. My question is why does my primer have so much orange peel in it. I have tried to adjust the gun and air pressure but no change. I'm using Duplicolor products and my gun is the gravity feed type? Thanks for the help.
euro67turbo
Re: Orange Peel? Need help
There are several factors that can cause orange peel ,
1. primer being too thick, may need to be "reduced" or thinned
2. too low spray gun pressure, must be around 20-25 psi on a gravity feed gun and must use a 1.5mm and up tip needle
just to name a few..
I personally do not recommend 1k primer/ surfacer , go with a 2k primer/ surface (primer + activator/hardener)
it is way more durable and easier to sand , and you wont get swelling or sand scratches after its painted. its worth the extra bucks!
- volksbugly
I've only experienced orange peel when I have pressure to high.
cvbug
I will try to lower the pressure and also may try thinning out a little.
bens collision
Yeh, what he said. And # 3. Its primer, its not intended to lay slickeuro67turbo wrote:There are several factors that can cause orange peel ,
- craigvwdude
Either to low of pressure or primer to thick.
Simple.
Simple.
