NEW IDF Throttle bodies
Paul H
Post by Paul H »
Latest product
IDF Throttle bodies
Sizes 38mm thru 54mm
Sealed roller shaft bearings with centre shaft support bush
Single center idle air adjusters can be top or side mounted
Vacuum balance channel and 1/4 npt outlet port
O ring sealed base
Stainless hardware
Profiled stainless throttle shafts
Long or short injectors
Various filter rams and turbo feeder available
Die cast heat treated body
38 thru 45 have dual tapered tract to match up to 48mm manifolds and intake pipes.
Bla Bla Bla
foreverska
Re: NEW IDF Throttle bodies
Post by foreverska »
vwspeedshop.com wrote:Price per pair
Any chance of these becoming available as a single?
Paul H
Post by Paul H »
Yes no problem would have to be a right hand one if you want TPS
SuperRSi
Post by SuperRSi »
AND the price is?
Paul H
Post by Paul H »
Basic 38mm thru 45mm are £350 ex tax which is about $520
That includes fuel rails,tps,and the ram pipes which accept 2 inch neck cone filters or turbo pipe.
The 48mm thru 54mm are a bit more because they have the larger radiused ram pipes to accept the 2 5/8 inch
neck filters- air filters are available from Bugpack.
Also available is a kit that will allow use of the oval type carb filters and a hex bar linkage.
Shipping to USA by Fedex or UPS is $50 whether 1 , 2 or 3 pairs
Vee Dub Nut
Post by Vee Dub Nut »
Paul H wrote:Basic 38mm thru 45mm are £350 ex tax which is about $520
Those look great! I'm definitely keeping these in mind as my motor plans change.
Fightin' Texas Aggie Class of 2006
67 Beetle
74 Transporter (SOHC EJ25)
See all my VW pics on Instagram @ vee_dub_nut
dannyboy
Post by dannyboy »
i picked mine up on saturday lovely finish on all parts :D
Wally
Post by Wally »
dannyboy wrote:i picked mine up on saturday lovely finish on all parts :D
You lucky b*st*rd! :lol:
Awesome product development Paul! Kudos for that alone.
They seem to be extremely well suited for turbo use 8)
Redline Weber
IDA Throttle bodies 62mm
Post by Redline Weber »
Hi Paul, what is your product ability for a 62mm IDA ?
Lance
Paul H
Re: IDA Throttle bodies 62mm
Post by Paul H »
Redline Weber wrote:Hi Paul, what is your product ability for a 62mm IDA ?
Lance
Nil :lol:
The IDA stuff is out in a couple of months - max is 56mm
Devastator
Post by Devastator »
Those look great! :D
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
madman4
Post by madman4 »
Oups too much click .....
MarioVelotta
Post by MarioVelotta »
I got my fix as well, these are great!
[email protected]
luftvagon
Post by luftvagon »
These look great.
1981 Volkswagen Vanagon Westfalia - air-cooled Type4 1970cc CV (hydraulic lifters, 42x36 valves, stock cam, microSquirt FI)
1993 Ford F-250 XL LWB Extended Cab 7.3L IDI
MarioVelotta
They are, if you want options this is the only way to go!
[email protected]
