Has anyone used Seafoam to clean injectors?
Posted: Sun Oct 20, 2013 6:53 pm
by Jim Ed
Has anyone used Seafoam to clean injectors or the fuel system?
There are a lot of good reviews for it on Amazon.com.
TIA!
Re: Has anyone used Seafoam to clean injectors?
Posted: Sun Oct 20, 2013 7:30 pm
by helowrench
I have always had really good results from Berrymans
Posted: Sun Oct 20, 2013 7:46 pm
I tried sea-foam vs. berrymans once in a very unscientific test, split some grungy parts put in two containers, allowed to soak and then sloshed around/rinsed...
Everything came clean.
The berrymans took off the paint as well.
Berrymans B12 costs ~1/4 as much. Your call.
Posted: Tue Oct 22, 2013 3:19 pm
by raygreenwood
Yes...its hard to beat Berrymans B-12. The chemistry alone is superior. For a fuel system cleaner I have never seen what anyone see's in Seafoam. Its basically paint thinner. It will help remove carbon when poured into a running engine...but then again so will water.
Ray
Posted: Tue Oct 22, 2013 4:16 pm
Ray--- please check your PMs...
Posted: Wed Oct 23, 2013 4:19 am
by andy198712
Water injection = steam cleaning
Not many people realise it, can't wait till its time to strip my old 1200 I've water injected so I can see my spotless chambers
Posted: Sun Oct 27, 2013 9:46 am
by Jim Ed
I didn't want to be off topic since this is an aircooled VW forum but, this was concerning a 1987 F150 pickup sputtering and being hard to start.
Previously I was driving it home one day and it was sputtering really bad and almost died.
I removed the fuel filter to replace it and what looked like liquid mud came out of the old filter.
After changing the fuel filter it ran a lot better but was hard to start when cold outside and would sputter occasionally. If I let off the gas a little and gradually press on the gas pedal it would run smoothly again.
I put one can of Chemtool in each gas tank.
The next day it was running smoothly and easier to start.
Thanks all!
