Twin port fuel injection
SHADOWBLADEKING
Post by SHADOWBLADEKING »
Hi guys. I'm relatively new here. Was referred by a contact of mine. I have absolutely no idea how to do a fuel injection on my bug. I have done some research on the subject and as of date know this: i need injectors, coil pack/s, Throttle body/ies, management system, modified intakes, fuel pump, return line. I was thinking of having an injector on each piston with 2 throttle bodies (one for each side of the motor) then use the original fuel line and split it to the injectors and with the throttle bodies use the same idea as with dual carbs for the throttle. I would appreciate it if anyone could help me. If I missed anything with the parts needed please inform me and ideas for the conversion would also be appreciated. Jean.
Jadewombat
Re: Twin port fuel injection
Post by Jadewombat »
E_bug
Post by E_bug »
Use the force :D (Mario)
My welding sucks .
