davidt's Scat 1915cc Megasquirt and Supercharged build
Posted: Fri Jul 25, 2014 12:33 am
I thought I'd start this thread for David here. He can answer all the questions as I just posted the pics only. After seeing these pics I think he might get a lot of questions re his build.
Quote from David:
You could fit an AMR500. It is a 500cc twin lobe rootes style blower from the Japanese Kia class of cars from the 1980/1990's.
I have fitted one to my 1915cc Scat engine in a 1972 Superbug. I run Megasquirt EFI and E85 fuel with 6 injectors, sidewinder style 1-5/8 stainless exhaust and a cold air filter box. Engine is making 7.6psi from a pulley ratio of 3:1 and that is the maximum the the blower will make with my size engine. Has awesome low down pull that turbos can only dream of (try 6.5psi at 1500rpm)
Just an update with my AMR500 fittment. She has been on the Dyno. Scat 1915cc, Megasquirt ECU & custom fuel injection, E85 fuel and AMR500 supercharger. Made 116hp (at the wheels) at 4900rpm but had a minimum of 110hp between 4000rpm and the rev limiter at 5700rpm. Maximum torque ran between 2500rpm and 4000rpm and peaked with around 525lbs of tractive effort. As a comparison a standard 1600DP makes 38-40hp and 250lbs of tractive effort on the same Dyno on the same day. After the Dyno session I found a loose L/H inlet manifold plus on the data logs the air-fuel ratio was in the 10's (quite rich) above 5000rpm so there may be more in the old girl yet. The boost varies depending on revs. During the Dyno run, the boost starts at 7psi at 2100rpm and then dips down to 5.3psi at 4100rpm and then climbs to 10.9psi at the 5700rpm limiter. Since the AMR500 is a positive displacement blower, the actual air getting pumped into the engine cannot vary, give or take pumping loses, etc. The boost pressure that is registered on a gauge is just a representation of the restriction of the actual air flow getting pumped through the intake system, cylinders and exhaust system. So I believe that the boost pressure is not actually dipping in the mid range. That is where the engine is at its most efficient and is flowing the best. On my Scat 1915cc engine the intake plumbing size, intake port size, valve size and cam profile are set-up for max torque in the 2000-3000rpm range and max power around 5000rpm. So in summery I think that if I ported the heads, fitted even larger valves and installed a more aggressive cam suited to Supercharged forced induction, then I would expect the boost to be more linear and the power would increase. An intercooler would really help as well but there is not enough space.
So if you are thinking of going the Blown route then I would recommend it. After all, "It is better to be blown than to suck".
Quote from David:
