Page 1 of 3
buying after market gauges
Posted: Thu Aug 28, 2014 9:43 am
by weldvair
My gauges on my 1971 look terrible......I want to buy new gauges but, do not know
if I can buy a after market fuel gauge that would be compatible with the ghia's fuel tank sending unit. Anyone have experience with this? The ammeter, oil pressure & volt meter I do not think
would be a problem.
Thanks Don
Re: buying after market gauges
Posted: Thu Aug 28, 2014 11:19 pm
by weldvair
I am not getting any responces so let me ask a different question......What is the
low/high ohm reading of the sending unit?
Don
Posted: Fri Aug 29, 2014 12:27 am
Not ignoring you, I'm sure Marc knows that off the top of his head.
The stock Ghia sender is IIRC as you note a resistive unit and can be made work on MANY aftermarket heads.
Only one caution: You tend to get what you pay for.
The "word" of the day is: Dakota Digital.
http://www.dakotadigital.com/
Above my personal pay grade but awesome quality.
Full disclosure: I'm highly biased against most off the shelf analog gauges: most any gauges I might buy at this point are going to be canbus, and actually calibrate-able, I'd rather have nothing than have to guess. I'd rather duct tape my laptop to my dash than suffer pretends-to-be-accurate instrumentation.
Posted: Sat Aug 30, 2014 1:17 pm
by weldvair
Thanks as always.....Don
Posted: Wed Sep 03, 2014 3:39 pm
Marc just postd/linked to a more complete description, apparently on ghias you may have resistance type or balance coil... I'm pretty sure Dakota Digital can set you up either way.
Posted: Mon Sep 22, 2014 7:42 pm
by FRNKNSTNGHIA
http://www.ebay.com/itm/NEW-Genuine-VDO ... d6&vxp=mtr
The are the gauges I am going to use in my 70 Coupe. Clearly have to modify the dash. Yet has all info I need, and the speedo is gps driven..
Posted: Fri Sep 26, 2014 5:29 am
by weldvair
Nice looking gauges.
Don
Posted: Thu Oct 02, 2014 6:05 pm
by flat_iv
Best ever! SpeedHut Gauges.
Posted: Sat Oct 04, 2014 8:44 pm
by FRNKNSTNGHIA
The great thing about the gauges I posted is that it has all the lights for hazards, oil, generator, etc. All the other gauges don't offer that so you have to get creative. These are much cleaner and set up for our type of wiring as well as our engines as the Porsche 356 used a variant of our beloved 1600cc..
Posted: Sun Oct 05, 2014 6:26 am
by weldvair
I'll let you do it first & see how it works out for you..........Don
Posted: Mon Oct 06, 2014 12:50 am
weldvair wrote:I'll let you do it first & see how it works out for you..........Don
Wise man.
Usually said as "You Go First"...
You get what you pay for. Sometimes.
Sometimes you get pretty dash filler that pretends to be actual instrumentation, for ~the cost of actual instrumentation.
Posted: Tue Oct 14, 2014 3:43 pm
by ghia1969
Hi.
I bought mine for my 1969 convertible from
http://www.speedhut.com. I can totally recommend them.
Here is a picture from their facebookpage:
regards,
norskghia1969
Posted: Fri Oct 31, 2014 4:53 pm
by weldvair
Nice looking gauges but, a little to expensive for my budget.
Don
Posted: Fri Dec 05, 2014 9:17 am
by RHough
My '72 "Amber" is at House of Ghia for a makeover this winter. I'm looking at dash layout options. I'm open to something period correct using the two big holes and adding gauges either in place of the radio or under the dash. I'm also open to having them hack a large hole and start with a clean slate or a combination unit.
I neglected to take good pictures so I can test layouts before deciding.
If someone can give me the gauge diameter I can probably scale something from photos on the net.
This unit from Dakota Digital looks good, but I don't know if a Ghia can handle a 5" x 10" unit.
http://www.dakotadigital.com/index.cfm/ ... prd884.htm
Posted: Sat Dec 06, 2014 6:19 am
by weldvair
They look great but, the price is also great.
I am leaning to autometer gauges.
Don
