Page 1 of 2
EJ20 notchback
Posted: Thu Mar 26, 2015 9:07 pm
by 55superbeetle
Re: EJ20 notchback
Posted: Fri Mar 27, 2015 8:08 pm
by panel
Love it! Really clean install for sure. Where did you tap in for the oil feed for the turbo and what material do you use for the water to run front to back ?
Re: EJ20 notchback
Posted: Fri Mar 27, 2015 10:19 pm
by 55superbeetle
The water pipes are 1 1/4 stainless steel, with gates hose connecting that to the motor. I moved the galley plug that has the factory oil pressure switch to the flywheel side of the motor and teed off that for the turbo feed, you can see the vdo sending unit in the pics.
Thanks for the compliment
Re: EJ20 notchback
Posted: Sat Mar 28, 2015 2:24 pm
by panel
Just to clarify you've now 'T'd off the new VDO location or where the factory oil pressure switch used to be. Reason I'm asking is I don't want to have a 36" piece of feed for my own install.
Re: EJ20 notchback
Posted: Sat Mar 28, 2015 3:14 pm
by 55superbeetle
Yes I used a T under the vdo sending unit. I don't think you would have a problem moving that galley plug to any of the other locations on the motor though. I'm sure you could easilly get another one of those plugs too, if you wanted to have a dedicated one for the feed.
Re: EJ20 notchback
Posted: Sun Mar 29, 2015 8:51 am
by saggs
Wow! Beautiful , clean job. Great attention to detail and stock looking from the street. I'm sure you got a happy customer there. I have a split camper I may put a subie motor in. Normally aspirated. What did you do for the swing axle tranny? Has that been beefed up or regeared for the motor. Also, did you need a rear engine support for the added weight and torque?
Nice Job
Re: EJ20 notchback
Posted: Fri Apr 03, 2015 9:44 pm
by Andym
Badass Jeff!!! You knocked this one out of the park!!
Re: EJ20 notchback
Posted: Wed Apr 29, 2015 9:24 pm
by simon_C
Oh nice, AJ showed me this car in person when it was up on the lift. Build looks top notch.
Re: EJ20 notchback
Posted: Thu Apr 30, 2015 2:49 am
by flyingfrenchmen
New guy here, trying to figure this out. Love this install great Job. Question what is the Methanol used for? I have only seen Methanol on some fast cars so just curious? Keep up the great work. Wish i was in the same state so you can do mine.
Re: EJ20 notchback
by flyingfrenchmen
Re: EJ20 notchback
Posted: Fri May 01, 2015 3:29 am
by dlamyle
flyingfrenchmen wrote:Question what is the Methanol used for? I have only seen Methanol on some fast cars so just curious?
This will help
http://www.turbomirage.com/water-alcoho ... ideos.html
Re: EJ20 notchback
Posted: Wed Jun 10, 2015 7:38 pm
by Stschritter
Great job. Been wanting to do this in my notch for awhile, but have the design to fit everything under the deck lid. Glad to see you were able to do it
Re: EJ20 notchback
Posted: Wed Jun 24, 2015 10:42 pm
by RonW
build quality top notch and very clean! well done
Re: EJ20 notchback
Posted: Thu Jun 25, 2015 12:13 am
by falcor
Very clean install, well done!
Re: EJ20 notchback
Posted: Sun May 15, 2016 12:35 pm
by 55superbeetle
Forgot to update this, car has a subaru 5 speed in it now. Took some work to get everything working properly but the end result is pretty awesome.
