2110cc motor on the dyno
- Paul H
This weeks thrashing of someone elses motor
Re: 2110cc motor on the dyno
Give us the details
- Paul H
Mapping a 2110 VW aircooled with AEM EMS-4 sequential fuel injection and wasted spark ignition.Initially tested with 38mm IDF pattern throttle bodies and then with 45mm VW Speed Shop manifolds and throttles.which made more top end power. Final test was to fit the taller ram pipes which made most mid range and top end power
