Flywheel oxy/waterboxer - 914 gearbox
Rob Habets
Post by Rob Habets »
Hi
Which flywheel can i use for a oxy/waterboxer combined with a porsche 914 gearbox, with either a 215 or 228mm clutch?
Waterboxer, porsche 914 or type 4?
Regards, Rob
Rob Habets
Re: Flywheel oxy/waterboxer - 914 gearbox
Anyone???
Any of them, but the non-914 flywheels need the input shaft bushing installed by a machinist.
(simple 5 minute mod drill/ream to press fit for the $5 bearing)
The 901 input shaft doesn't go all the way into the crank, like a T1 trans.
I run a 228, barely worn at all after 200+K miles. You could still barely read the painted on SACHS markings on the friction surface.
Rob Habets
So the ring-gear offset is identical on all of those flywheels?
The input shaft bushing position is the only difference?
Rob Habets wrote:So the ring-gear offset is identical on all of those flywheels?
Identical, no.
Close enough for good starter engagement (tooth mesh/depth)?
Yes.
The "real"914 FW ring gear "projects" a lot more (longer teeth) but the starter engagement on the 228 I installed was fine, and its pretty much in the same place as any other T1/T4 12v ring gear, give or take a mm.
Rob Habets
