Hello all, I am working on a 1745cc engine to put into my squareback currently and am converting to MS FI and ignition.
As I said it will be 1745cc with a 76mm crank, 85.5mm cylinders, Eagle 2231 cam, stock rockers, stock valves, and the VW Speed Shop "Throttle Manifolds".
I would like to know some injector recommendations based on this size motor. I know that there are different pulse lengths and such I just don't know what would be good for this application and I don't really wanna buy more injectors than necessary!
Thanks!
Fuel Injector Recommendations?
Re: Fuel Injector Recommendations?
You install Fuel injectors based on your hp estimates or goals.
I use 32# Bosch injectors from a 1994 Volvo 940 Turbo and they are 336cc's and good for 230 plus hp on my 1679.
You also have to decide whether you will run Low-Impedence or Hi-Impedence injectors. It will depend on how your MS ECU is set up.
Pick an injector that will service the hp you have now and what you think you will need in the future.
- Max Welton
Yes. Pick injectors that are spec for any 4 cylinder engine that puts out about the same HP as your engine will generate. As long as you are in the ballpark, you will be fine.
Max
Max
- nogoodwithusernames
Thanks for the replies, should help me out in my decision.
I assume that I could also pull injectors from any size engine so long as I do the math and the per cylinder HP is the same?
There are different physical sizes with injectors also.
You will want to get the style that fits your intakes.
Don't forget to check on the Low-Z and Hi-Z also.
There are plenty of sites listing injectors and flows that you can narrow down your search on.
Post your hp estimates and someone will recommend a size.
I just checked my logs and I am at 94% Duty Cycle with my injector flows.......it's time to look for bigger ones.
Yep, my manifolds/fuel rails will need 14mm IIRC, I can check that again though before I finalize anything.
I plan on running Hi-z (based on reading through the MSextra manual the Hi-z seems easier to setup since they don't require any inline resistors or such.)
Got a link for one? I wouldn't even know where to begin looking to find a site like that
As far as HP I'm hoping to get 70-80, although with this being my first build that may be a bit optimistic. It will be a balanced 1745 stroker with stock heads and approx 9:1 compression.
Here is a calculator for you to figure your size.
http://fuelinjectorclinic.com/flow-calculator
Just plug in your data....using 80 hp at crank I came up with a 14 lb. per hour injector. A 19 lb. per hour injector would work fine for you but You could easily run 32# per hour and have room if you ever want to increase size or turbo it....
Here is a list of lots of injectors and their flow rates.
http://www.autospeed.com/cms/article.ht ... ows&A=0102
Like I said before......don't get too small of an injector....you want a little headroom.
I have a 1679 and it runs great with a 3.3% duty cycle at idle all the way up to the 94.5% at 22 lbs. boost on the 32# injectors I am using.
- Chip Birks
I bought from injector.com once. Prices are decent. Just remember, you are buying new parts, not junkyard stuff. Nothing wrong with hitting the junkyard either. I haven't ever used used injectors since my power goals have generally been higher than most oems offer, at least cars that are in the typical junk yard here.
