Hi,
anyone got a megasquirt MS2 V3.0 for a 2.1 DJ or maybe 2.1 MV engine.
I need it as a starting point to get my engine set up with the K-data KDFI management-system, which is based on the MS2.
Regards, Rob
Megasquirt MS2 V3.0 map for 2.1 Wasserboxer
Re: Megasquirt MS2 V3.0 map for 2.1 Wasserboxer
ill post mine here in a bit, but my map is for a boosted 2.1.
Even better, mine's to!
It's a 2109cc turbocharged Oxyboxer based on a 2.1 WBX.
So your map could be a damn good starting point.
- Chip Birks
Hold on a sec...so the only wbx parts are crank and case, but aircooled everything else? Why would you want a wbx tune if your motor is not a wbx? What cam, heads and boost and ignition will you be running?
im going to have to agree with chip here. you do know that tuner studio more or less comes with a map good enough to start the motor on if you know what your doing. with that, you can then just start tuning from there.
