Budget street legal rail (re)build (WARNING: pic heavy)
Posted: Thu Jan 14, 2016 11:58 pm
I decided to put a condensed version of my build thread from TOS over here so everyone could follow along easier. That thread is already halfway through page 12 and I have over 300 pics in my Photobucket album. This is gonna take a while to get it caught up, so I'm gonna try to just put the essentials in here until I'm caught up. Retyping everything won't be easy, so I'll just put a summary comment above each pic explaining what I was working on in that pic. If anyone has questions or comments just post them up and I'll try to answer them as best as I can. On to the pics!
The rail as I received it:
I got the rail this past summer by trading a dirt bike for it. It ran, but had lots of issues. Rear tires are 31's and the fronts are stock bug 165's. Note the downward sloping angle from back to front on the bottom of the frame.
It has a home built frame with some very questionable parts on it. This was one of the scariest looking pieces on it.
Hyd line lock, cutter brakes and the regular brakes didn't work. The E-brake parts weren't installed at all. The shifter was as sloppy as a soup sandwich.
The 1600 DP engine is in fair condition, but it had to breath through that badly kinked stinger. It has oil and fuel leaks everywhere. There is an external oil cooler on it, but no filter.
The stock rear arms were boxed, but I don't like the single shear shock mounts. That will get fixed in the future. Brakes are stock bug parts front and rear.
The Porsche 356 steering box was a nice surprise. But the wasted TRE's and bent tie rods, not so much though. The steering U-joints are shot, but they are welded to the steering shaft and the steering box input shaft.
The rear rack was one of the things I liked about this rail. I'll like having the cargo space for carrying stuff.
I'm not sure how the PO managed to do that to the top of the shock.
The steering wheel was almost directly in the middle of my field of view when seated. The bearing block is also cracked down the middle. Seats are FG high backs with old and stiff vinyl seat covers.
There were obviously some issues with the steering stops as indicated by the rashed bodywork on the pass side.
The longer rear shocks are fine, but the single shear mounts on top and bottom, not so much.
Poly gas tank works for now, but I want to put in a stainless or aluminum one. If I swap to an EFI engine later I want to be able to weld the tank as needed. The red key to the battery cut off switch was snapped off flush in the switch.
This is my biggest issue with the frame. The axle is welded directly to the frame and it looks like the PO ran into something HARD with it. The beam is bent back on the pass side, and the frame is tweaked up on the same side looking at it from the front.
The rear torsion housing is also suspect due to about six layers of angle iron welded all around it. I found cracks on the bottoms of the horns as well.
Headers are rusty, but not rusted through anywhere yet. The vent on the valve cover is supposed to go somewhere. Not be left open to the atmosphere, especially on a vehicle that sees any off road time.
That's enough for now. I'll start on posting the work I've done to it so far.
