Shortened oil pans
sweetguth
Shortened oil pans
Post by sweetguth »
Hey chaps,
Who makes a good shortened oil pan. The stock one is causing clearance issues. Or is there a DIY method to gain a few inches of clearance? I have a suby 2.5
panel
Re: Shortened oil pans
Post by panel »
Most Subaru builds have made them or had them purchased. Couple of my favorites is here though:
viewtopic.php?f=19&t=147592
viewtopic.php?f=14&t=147567
billz60vw
Post by billz60vw »
it also depends on the motor mount! the subaru gears mount raises the engine i think 50mm from stock.so no short oil pan needed or at least i didnt need it.the frame rails are lower than the sti oil pan i am running.
surfbeetle
Post by surfbeetle »
I cut one down and made it. It seems to be okay. I would have preferred to get one of the many that I have seen professionally made but they all seem to cost $500 US.
_______________
'67 Bug EJ20 Turbo
Build Thread
Iguana
Post by Iguana »
We make the best shortened pan on the market and from what I can see the shortest by over 1" which means a lot when your dragging ya ass.
Same internal capacity as stock and over 15 years without issue.
http://subistuff.com/subi-conversions/s ... -sump.html
Buy a Kit, Build a Dream
H2OSB
Post by H2OSB »
Anyone make a shortened oil pan that works well for high g maneuvers, i.e. autocross?
