Under body paint
Ram
Under body paint
Post by Ram »
Hello
Im building a baja bug, the body is of the pan , i have allready removed the paint and epoxy primed it and over that I also sprayed 2k primer .
My question is , on the lower parts under the body should i paint it with regular color and then do a coat of regular rubberized undercoat or can i skip the regular color stage and just spray the undercoat?
5.0 Chero
Re: Under body paint
Post by 5.0 Chero »
If you are going to use regular rubberized undercoat then yes I would shoot it with both Base and clear coat and let it set up before using the under coating. I am going to use Upol Black UP3000 U-pol Truck Bed liner on the top and bottom of the pan on my Baja, it can be shoot over the 2k primer with out any issues will seal the pan and hold up a lot better than under coating
