Aftermarket fuel injection with dual throttle bodies???
ecksrash
Have any of you attempted to do an aftermarket ( ie megasquirt ) conversion on a type 3 and use dual throttle bodies? I'm hung up on figuring out a filtration system... ant ideas are welcome.
- aircooledtechguy
Re: Aftermarket fuel injection with dual throttle bodies???
I've used MS in my car for years, but I'm running a type4 motor. Since ITBs are really no different than carbs, the same filters used for carbs should work just fine.
