Page 1 of 3
Land Speed 1915 Turbo build
Posted: Sun Jun 11, 2017 10:19 pm
by WickedWagens
I never got to finish the EFI turbo setup for my Ghia that I started years ago. I am now racing in a "classic" category at Bonneville which allows no electronics. I want to switch from the normally aspirated classes that I raced in last year and go to the turbo class. I have a displacement limit of 122.9 cu in. For this year I chose a 1915 cc for what I thought would be an easy straight forward build. It is starting to get interesting. Here is what I have so far.
New AS-41 case
DPR 69mm crank chevy/buick journal
I'm looking at 3/8" ARP bolt 5.6" H-beam rods
The cam is a R304 from Shag @ SL-1 racing .521 lift 304 duration
94mm AA True Forged pistons and cylinders
AC.net revmaster 049 L6T heads
RLR 4 barrel drawthrough carb
I'll get some pictures posted as I start to assemble.
Re: Land Speed Turbo build
Posted: Mon Jun 12, 2017 6:52 pm
by petew
Do they let you have an wideband/AFR meter on it?
Posted: Mon Jun 12, 2017 7:21 pm
by WickedWagens
Yes, you can data log, just nothing to control fuel or spark.
Posted: Mon Jun 12, 2017 10:05 pm
by petew
I guess the altitude at Bonneville makes tuning more interesting anyway right? Could you run much lower octane fuel and have less issues with going lean?
Posted: Wed Jun 28, 2017 12:39 am
by Wally
Land Speed and turbo sounds like a great combination to me
Please keep at it. Pity you didn't got the EFI set-up going...
Posted: Wed Jun 28, 2017 8:30 am
by WickedWagens
Yes, Hopefully the EFI turbo setup from the Ghia will make it into my VW 181 someday.
Posted: Wed Jul 19, 2017 1:23 pm
by WickedWagens
Checked all bearing clearances and started to assemble.
Posted: Fri Jul 21, 2017 5:22 am
by andy198712
sweet, all go together smoothly?
Posted: Fri Jul 28, 2017 3:27 pm
by WickedWagens
Yes, Short block is complete. I'm just waiting for the cylinders from the machine shop and the new turbo from Shag.
Posted: Wed Aug 02, 2017 2:54 pm
by WickedWagens
I had Herbert Performance hone my cylinders to .006" piston to cylinder clearance and I set the ring gap to .023" top and .024" second.
long block done.
Posted: Wed Aug 02, 2017 9:46 pm
by ToRy 70
Is that a base for a magneto? Never seen a dizzy like that. How will you control boost related timing? Cool project.
Posted: Thu Aug 03, 2017 11:54 am
by WickedWagens
It's the base for the CB Magnaspark distributor.
Posted: Fri Aug 04, 2017 12:44 pm
by WickedWagens
It's in the car. Still some fabrication to do, but it's getting close. Little things now.
Posted: Sat Aug 05, 2017 12:35 am
by rubenski
Sweet!
Posted: Sat Aug 05, 2017 3:53 am
by madmike
