It has been a while since I posted here, but I had a build thread both here on the efi-forum a few years back, and over the years I have received invaluable help from you and also the guys over at the EFI-forum.
The intention with this thread is to update you on the progress, so maybe someone out there can learn from my mistakes, but also to get some great advice as the build progresses over the winter.
Just to start off with a short recap of a current description of the engine as I used it this summer/fall:
-2.1 l WBX case modified by myself with mostly hand tools
-Fully balanced stock 76mm wbx crank
-AA flywheel
-Cylinder adapter rings from Rocky
-94mm Cima barrels machined to correct diameter/length locally
-Scat I-beam rods
-Wiseco 94mm pistons
-CB 043 Los Panchito CNC ported heads (40x35.5mm)
-dual tapered alu pushrods from aircooled.net
-Pauter 1:1.3 rockers
-CSP Python exhaust
-Microsquirt ECU
-38mm throttle bodies from VW Speed shop/The dub shop
The oils system consist of a sandwich plate between case and filter and one external cooler. More on this later
Installed in my daily driven Ghia it looked something like this:
