I am working on a friend's box that has a threaded pinion shaft. I have changed the 3rd gear.
Is there a way to adjust the shim to compress the bevelled washer correctly without the VW299 tool?
Sent from my ONEPLUS A5000 using Tapatalk
Shim for solid spacer on threaded pinion shaft
paul_f
Casting Timmy
- Pablo2
Re: Shim for solid spacer on threaded pinion shaft
I think I used my #299 once .. Pretty much all of us have opted to eliminate the "springy" feature, and shim the sleeve to be tight when everything's bolted together. Berg was probably the first one to recommend doing this ..
aka Pablo, gears, Geary
9.36 @ 146 in '86
9.36 @ 146 in '86
paul_f
Thanks both, I will follow the Berg book then!
