in tank fuel pump
turboedbug
in tank fuel pump
Post by turboedbug »
anyone runnin am in tank fuel pump.
whats your setup. howd ya convert the tank to accept the pump
Sent from my SM-J727T using Tapatalk
Turbo!
kangaboy
Re: in tank fuel pump
Post by kangaboy »
Is there any advantage to doing it? I think most of us just use out of tank pumps.
'74 Standard- 2084T, MS3X3
'76 Westy- Stock 2.0L L-Jet
My Megasquirt Turbo Build
2084 Turbo Build
risk
Post by risk »
kangaboy wrote: Thu May 17, 2018 7:50 pm Is there any advantage to doing it? I think most of us just use out of tank pumps.
I went from external pump to in-tank.. but I kept having aeromotive pumps fail so they upgraded me for free.
It's night and day difference in noise. In tank is pretty much silent, plus being submerged in fuel keeps the pump cool.
Here are some pics of it in my car.
http://www.shoptalkforums.com/viewtopic ... 2#p1261412
The pump kit came with a foam surround and "funnel" to help install it.
Post by Chip Birks »
I agree with Risk. Super quiet, also doesn't take up any extra space. No more need for an inline prefilter, i just have one stuck to the bottom of my pump inside the tank. Works great!
turboedbug
ya gonna order me some crap and see how it goes together.
i didnt like the location under the tank it wasnt the most easy to get to spot.
Turbo!
petew
Post by petew »
I saw this setup on mightycarmods the other day. Wish I had this a few years back. :(
andy198712
Post by andy198712 »
i think a tricky bit is later tanks don't have a nice flat part to bolt it to if my memory serves me, i guess you could cut a big hole and weld it in though?
turboedbug
andy198712 wrote:i think a tricky bit is later tanks don't have a nice flat part to bolt it to if my memory serves me, i guess you could cut a big hole and weld it in though?
gonna find out here in a lil bit ordering an in tank setup now!
Turbo!
risk
Post by risk »
The kit I used had about a 1" thick foam gasket on top so you didn't need a flat spot really.
woodsbuggy1
Post by woodsbuggy1 »
I run an intank pump from a 93 Subaru Legacy, has worked great with E85 for over 4 years. Since I have a railbuggy the tank was built to fit in the space available(behind passenger seat) and the subie pump assembly just happened to have the correct angle to match the seat. I think it would be worth building or modifying a tank to take advantage of an intank unit and if you use one from a production vehicle than are easily available at most any auto parts store.
Good Luck
Kenric
MarioVelotta
Post by MarioVelotta »
Chip Birks wrote: Fri May 18, 2018 11:18 am
Do you have a thread about your conversion on here?
[email protected]
MarioVelotta wrote: Tue Jul 31, 2018 9:14 pm
One post In my turbo build thread.
viewtopic.php?f=3&t=131345&start=405#p1217728
Mathias
Post by Mathias »
I build my own version of the Phantom-setup. much smaler hole, but the main reason was that the phantom (at the time i looked at it) was not supporting E85, so kit+ E85 pump was too much $$$ for me.
[img=http://forumbilder.se/H7QG4/img-1422.JPG]
risk
Post by risk »
Here is a pic of the pump that came with the phantom E85 kit.
And a link here:
http://walbrofuelpumps.com/450lph-walbr ... 00267.html
eanico
Post by eanico »
Will the phantom fuel pump support E85 as is, meaning non-e85 kit?
