Alternator
Booky
Alternator
Old alternator was putting out 17.35 volts way to much.Put on new alternator it’s putting out 15.15 is that ok.All with using multimeter.
- Dale M.
Re: Alternator
It's a little high but probably with in limits....
Dale
Dale
66brm
Re: Alternator
It's important to take into account the condition of the battery and wiring, normally the regulator will limit output to 14.4v. If the battery is questionable or the wiring has higher resistance then the alternator will run at maximum capacity
