any ideas what this is
kiaora73
Post by kiaora73 »
https://youtu.be/YEVQjxF9K1Y
a squeaking... it sounds like it's coming from the carb. May be the head I can't tell.
any ideas?
Sent from my SM-G925F using Tapatalk
risk
Re: any ideas what this is
Post by risk »
first thing I would do is run it without the fan belt for a few seconds and listen.. that will rule out the fan squealing. Then move on to the carb or head.
kiaora73
Post by kiaora73 »
risk wrote:first thing I would do is run it without the fan belt for a few seconds and listen.. that will rule out the fan squealing. Then move on to the carb or head.
hi cheers already tried that.. still sounds
66brm
Post by 66brm »
It's one of your gaskets vibrating as air passes by it, creates a whistle sound. Either your carb or manifold is loose or the surfaces are not flat
kiaora73
Post by kiaora73 »
ok cheers I'll check it out.
66brm wrote:It's one of your gaskets vibrating as air passes by it, creates a whistle sound. Either your carb or manifold is loose or the surfaces are not flat
kiaora73
Post by kiaora73 »
66brm wrote: ↑Sat Sep 01, 2018 2:52 am It's one of your gaskets vibrating as air passes by it, creates a whistle sound. Either your carb or manifold is loose or the surfaces are not flat
Took the carb off and the manifold. Found a small bit of old gasket stuck to the bottom of the manifold... Cleaned the surfaces up.. Now sorted.. :)
66brm
Post by 66brm »
Cool, only reason I know is.... Mine did it, loose carb to manifold nuts
