I got a ad in the mail from HF and looking at it there was a light duty (300# loading... I doubt it) cart for a decent price ($20 plus tax) but would it be strong enough. I went on line (twice) and read the comments on it, especially the three bottom scores then drove over to look at it. They had it along with several others all wire tied together so you could see much but I did squat down and reach under and felt. I am sure the trans will be safe on it so I bought it. It seems I found a Christmas present cart which had $23 on it so I bought two (for the trailing arms with disc brakes mounted). So... going from what the negative accounts said I present the following (sorry guys but I over detailed as I think some of it might be needed assuming anyone else had brain fade like me).
I comes in a wedge shaped box. Everything is put together with the exception of the wheels which also comes in a box. One of the complaints was that the wheels suck... then come not lubed so I slathered them with silly cone and, while being light weigh units, the silicone did make a difference.
The next complaint had to do with the bolts. They came in their respective locations and fairly tight. Carefully I loosened them but did not remove them until all were loose and this allowed me to make sure that the backing plate did not fall out like at least one of the complainers had problems with. I do think the bolts around the edge would allow access to the inside but I was being careful. If there had been a problem then I could have put the caster with a bolt in place on one corner so the backup did not fall away when I remove the rest of them. Everything on mine was OK, no problems.
The instructions say to put the swivel wheels at the opposite end of the push bar but suggestions in the complaint area were to put the under the end with the bar (push handle). The instructions said that when you wanted to turn with the wheels up forward you stepped on the rear of the cart (to lighten the load on the front I guess) then turn. The way I have it now you move the back of the cart then go forward. Very changeable if I want to and no... do not put both of the caster on one side and the two non-swivel wheels on the opposite side. That will P... you off if you try to move it
Wheels on!
Cart turned over sitting on it's wheels. The push bar is folded down.
Finished.
When I am done with it (or the other one I bought this might be another use for it.
One of the other complaints was how does the push bar go down. The instructions said the step on the back and push but eeeeen... no. Channel locks hoooking into the ball area, tilt forward, push forward on the bar to lock that device then attach the other vise the same way. It'll go down OK then.
