spark plugs
spark plugs
hi im building a fuel injected turbo 1600 using ms3pro evo what spark plugs are you guys using ?
Re: spark plugs
Not a turbo though
- panel
Re: spark plugs
Just an FYI......Those are 14mm. Meaning , make sure you don't just run out and buy those in case you're running 12mm heads.
Re: spark plugs
im running stock 1600 everything so would that mean i have 12mm?
Re: spark plugs
Stock t1 is 14mm 1/2" reach, t4 is 14mm 3/4" reach
Re: spark plugs
I run an NGK plug in my stock heads but it is one number colder than stock. I can't remember the number though.
You will be fine running stock plugs for your specific heads. Once you get way up in boost you could try a one step colder plug but for 10 lbs and under stock is fine.
Leave the gap at the stock .024"-.028" too....no matter what ignition you run. I've never had any issues at these settings.
