Drag and Drive Baja
Schweg
Drag and Drive Baja
Post by Schweg »
Wanted to start up my build thread so you guys can help and I can log what I have going on.
Inherited the car, was into motorcycles for a long time mostly air cooled. This is my first VW, I have lurked around the forums and more recently sent some PM’s but that’s about it.
Pan is a 69
Body is a 74
Link pin front ( not sure on the rear)
1600 ish cc ( haven’t pulled it apart to check)
Stock everything as far as I can tell
Currently I’m mid EFI install:
MS3PRO 1st Gen
LS injectors and coils
Innovate PSB-1 wideband and gauge
Need to buy:
injected manifolds
Fuel pump
Fuel pressure regulator
New turbo header
I have a Nissan 45v3 turbo off of a Skyline that I currently have running blow through on a PICT34 and a locked out distributor. Tried 3 different runs with jetting to make boost and never had luck. I wanted to go EFI just didn’t know it would be this soon.
Ultimate goal is around 250hp running E85 or water meth injected 91. I also have a Holeset HX35 waiting in the wings. Time will tell if the little 1600 will spool it, or I may just build a compound turbo set up.
Thanks for reading.
Schweg
buguy
Re: 1600 Baja Turbo/EFI
Post by buguy »
Sounds like you have some fun stuff in the works!
Schweg
Post by Schweg »
We will see, need to figure out how to post up photos.
V8Nate
Post by V8Nate »
The tapatalk app works great
Schweg
Post by Schweg »
Here is my super shade tree header. Replacement will be in soon
buguy
Post by buguy »
That's not a holset turbo?
Schweg
Post by Schweg »
That is a holset, I had no luck making boost with it ( could have been any number of issues ) went over to the skyline turbo. Then after a few rounds of jetting I said screw it and started building an EFI set up.
buguy
Post by buguy »
Oh!
panel
Post by panel »
If that was my car I'd twist that up pipe (wastegate) to the turbo 180° or at least 90°.
Schweg
Post by Schweg »
panel wrote:If that was my car I'd twist that up pipe (wastegate) to the turbo 180° or at least 90°.
I’m getting a new header, I’m not real happy with my own fav skills or the material I have available.
But yes looking back I should have turned it the thought never crossed my mind.
rubenski
Post by rubenski »
We all gotta learn!
rubenski wrote: ↑Mon Apr 22, 2019 12:03 pm We all gotta learn!
Very well said but some of us take longer than others :lol: .
Keep up the good work on your buggy.
Schweg
Post by Schweg »
Lee,
I’ll keep up the work. No guarantee on quality.
Schweg wrote: ↑Mon Apr 22, 2019 2:17 pm Lee,
:wink: Quality comes with practice, mistakes and learning from them and sometimes with the help from others. Again, keep going forward; heck, look at how long my build has gone on; I have learned (and forgotten) so much over the long build.
Schweg
Post by Schweg »
Thanks I will, looking to make some good progress after I make it back to town.
