I have a 1973 Beetle.
How often should I re-torque the heads?
TIA!
Head Re-Torque - How Often?
- SCOTTRODS
Re: Head Re-Torque - How Often?
In order to "retorque" the heads, you have to pull the tins on the engine (most of them anyway), so unless you have a dune buggy and it gives you easy access... You should only do this when you have the engine out for whatever reason. It makes little sense to torque just the lower head fasteners, which is all you can access without pulling tins. If you only torque the ones you can access... it applies Uneven torque to the head. In my opinion this is less than desirable.
Bruce2
Never. They don't come loose.
- sideshow
The last time I retorqued it was to troubleshoot a leaking head, turns out the head stud pulled out of the case (late non inserted 10mm case). Generally speaking the late 8mm cases never need to be retorqued, however I see no harm in doing the lower studs as a check.
