Uneven Pad Wear
Bad Bob
Uneven Pad Wear
I found this today while repacking the front wheel bearings on the left side. The right side had even wear. What causes this and what’s the fix? I’m thinking a stuck piston?
eskamobob1
Re: Uneven Pad Wear
Could be a few things, but stuck piston is high on the list if you have non-floating calipers. How does your rotor look? If you have a floating caliper (lots of bug disc kits do) you could have a caliper that isnt centering. I would expect some break warp from that if you tend to stop hard if that was the case. Was the smaller pad on the inside or outside?
Bad Bob
Re: Uneven Pad Wear
My calipers are non-floating. The smaller pad was inside. I’ll see if I can remove the outer piston and see what’s going on in there.
