Type 4 EFI intake manifold
MegaManx
Post by MegaManx »
Does anyone make webber style intake manifold's for the type 4 with bosses for injectors at the port? (Like the OEM set up). I swear I have seen them before somewhere, or is everyone just welded the bosses on?
I want to try and attempt a twin injector per cylinder staged injection set up on my turbo EFI engine that I am building. Ideally i would like to run one injector at the port and one higher up near the plenum.
Sent from my SM-G930F using Tapatalk
Re: Type 4 EFI intake manifold
Post by Chip Birks »
Why 2 injectors per cylinder? Are you hoping to make 1000hp with the combo?
MegaManx
Post by MegaManx »
No not quite that much, this isn't even a race motor!
The idea behind the twin injectors is primarily for cooling. I will be running E85 on this engine, and one of the big benefits of E85 is that it evaporates and cools the charge air and the heads really well. And the longer it is in contact with the air the better it works. So the idea is that i will run a primary injector at the port and then a secondary injector (much smaller than the primary) further up the intake runner that comes on at a certan RPM (E85 does need a good amount of air velocity to keep it atomized and off the runner walls) or boost pressure to cool the air, like a water meth set up, which cools the head and better prevents knocking. Well in theory thats how it works, it will take a fair bit of work to get right.
The spot I want to put my intercooler is only small so i want to achieve as much cooling effect as i can, Especially in an Australian summer.
I will obviously have to weld in bosses for the upper injectors, so its not a problem to do the lower ones, would just be handy if it was already done.
MegaRookie
Post by MegaRookie »
Hi,
The sell them by Orratech in Germany :D You just have to drill the injector hole yourself.
https://www.typ4shop.de/Luftfilter-Gest ... :1293.html
Best regards Mark
MegaManx
Post by MegaManx »
Great! Thanks Mark!
MegaRookie
MegaManx wrote: ↑Wed Sep 11, 2019 3:47 am Great! Thanks Mark!
:D Just ask if you want a picture of any detail. I have them here for my new engine.
Mark
patto
Post by patto »
Ill just leave this here 8)
Ephry73
Post by Ephry73 »
Cb performance used to sell the jenvey 48ida style throttle bodies. Also a great choice. More of a TBI but the sound
MegaRookie
patto wrote: ↑Wed Sep 11, 2019 11:32 pm Ill just leave this here
Nice! :D Which brand are these?
Thanks! Mark
patto
Post by patto »
MegaRookie wrote: ↑Thu Sep 12, 2019 12:47 pm
Thanks! Mark
They are EFI Hardware from Australia
MegaManx
Post by MegaManx »
Yeah they do some nice gear. If I was going Naturally aspirated, a set of those would be high on the list.
