Have you guys seen these yet? CNC machined solid aluminum T4 pushrod tubes in normal(209mm) and extended(209/214.5/220mm) length. Supposed to provide extra clearance, and should eliminate pushrod tube spacers in some cases.
https://www.csp-shop.com/en/engine/push ... 9491a.html
CSP extended length pushrod tubes
Re: CSP extended length pushrod tubes
Nice bit of kit!
- Wally
That is indeed pretty cool: new custom parts for the type 4!
- Clatter
My favorite part of these things is the little ‘removal ring’ for you to pry against.
Genius!
I’m still lost as to how you are supposed to remove stock pushrod tubes without messing them up..!
Genius!
I use a pair of snap ring pliers to grip inside and pull them out
- Angelo Amato
I have these in standard length and can confirm they are good quality (just fitted them recently). Still got an issue with a couple leaking at the head end depsite using the viton green seals (came with the tubes) and taking great care, will be sorting this out.
Only observation, they are billet so a bit thicker walled than the standard tin ones. Got a bit tight on my merger headers, only slightly so fettled the header to suit ever so slightly.
The CSP tubes are reduced in diameter at the exhaust ports BTW.
Angelo
Angelo
- Bills914-4
EMW (EuropeanMotorWorks ) sells them ,I have them on to different stroker motors , they are also narrow at the exhaust
port area & double o-ring @ case end ,plus they sell the Brown Viton O-rings , Bill D.
http://www.europeanmotorworks.com/pvw/0 ... shrod+Tube
Here's picture of mine I sent them out for black anodize thu my work
Bill DeWitt
2800cc 914-4
TwinPlugs & MegaSquirted
Now Boosted 7-10 psi
Weekend Therapy
2800cc 914-4
Weekend Therapy
