Distributor curve
Posted: Tue Oct 29, 2019 2:22 pm
What would be an ideal optimum curve to shoot for in a 1972 Westy hardtop with the following setup?
1972 Westy 2056cc T-4
AA 96mm biral P/C's
42x36mm Headflowmasters re-worked
Porsche swivel adjusters
71mm stroke
73 Web cam w/Web solid lifters
Bosch SVDA (timed @ 28 full 7 initial)
NGK BP6ET plugs
Pertronix ignition module
Pertronix Flamethrower 40K
Weber 40mm IDF's (47.5 idles, 125 mains, F11 tubes, 190 air corr. 28mm vents) LM-2 tuned
002 Trans 3-rib stock gearing
Hankook 185R14's
AA 96mm biral P/C's
71mm stroke
NGK BP6ET plugs
Hankook 185R14's
