Back up light switch
kg2457
Post by kg2457 »
How in creation do you get into and reach for the back up
Light switch on an AT 4 speed from my kg?
Thanks,
Bruce2
Re: Back up light switch
Post by Bruce2 »
What are you trying to do?
kg2457
Post by kg2457 »
Rearranging the wiring in the engine compartment
And want to be able to reach the two electrical contacts.
Is there a trick here?
Bruce2
Post by Bruce2 »
You should be able to re&re the connectors using your needle nose pliers.
