Brake light switch connector
kg2457
Post by kg2457 »
Looking for brake light switch connectors for my 1972
Ghia. It’s a plastic piece the pushes onto the switch for
Power and brake light
kg2457
Re: Brake light switch connector
Post by kg2457 »
Another issue is replacing the shifter bushing.
I replaced the bushing and trying to push the shift rod past new bushing and found it amazingly hard to do. So do I just apply pressure of tap it with a hammer?all good and lubed.
FJCamper
Post by FJCamper »
You must be missing the factory connector. I've never been able to find one, Just splice female connectors onto your wires. Also, the shifter bushing is a really tight fit. Muscle it in without damaging the bushing.
kg2457
Post by kg2457 »
Aye aye
