1776 with 46cc heads
joe-ker
Post by joe-ker » Thu Jan 30, 2020 4:45 pm
Did a little bit of searching but didn't see anything.
I can get some heads but they are 46cc chambers
My question is that to small, even though I would end up with 9.0 compression, which I know that has been posted, but with no one is saying their chamber size.
This will be a daily driver 65 vw bug
woodsbuggy1
Re: 1776 with 46cc heads
Post by woodsbuggy1 » Fri Jan 31, 2020 8:56 pm
It would depend on what cam you are using and what the recommended compression ratio is for that cam. What is the rest of your engine combo?
Kenric
joe-ker
Post by joe-ker » Sat Feb 01, 2020 9:53 am
not sure on the cam, but possibly a web series cam with 1.1 rockers. Kads, 1 3/8 exhaust
just wasn't sure if the chambers were to small
saltracer
Post by saltracer » Sun Feb 02, 2020 10:47 pm
You can run that compression and something like a 163 or 218 quite easily. A lot of builders will run a tighter deck and a bit big of chamber to get a certain compression ratio but a .060 deck is more than acceptable.
