2.8-4 N.A. converted to TURBO
Bills914-4
Post by Bills914-4 »
Time to share what I did with the parts I purchased to turbo a 914-4 , early last year I acquired some parts to finally
install a turbo on 914-4 , I'm in the process of building a 2.5 turbo but it's not ready , so I decided to fabricate and install
the parts on my 2.8 twinplug 10.7 c.r. type4 that is already in my 914 , here's is my build thread from years ago, it is now,
Gen.3 with AA long barrels I had Ionic plasma coated inside for less wear ,& new pistons with swaintech coatings, I couldn't
quiet the used aria's pistons,
(www.shoptalkforums.com/viewtopic.php?f= ... g#p1200260 )
Here's a few pictures from my journey :)
programmable water-meth inj. (boost juice)
Fabrication begins :) , spring/summer of 2019
more pictures to follow :)
Bill DeWitt
2800cc 914-4
TwinPlugs & MegaSquirted
Now Boosted 7-10 psi :twisted:
Weekend Therapy :D
Bills914-4
Re: 2.8-4 N.A. converted to TURBO
More pictures
Bill DeWitt
2800cc 914-4
Weekend Therapy :D
Clonebug
Post by Clonebug »
Very Nice!!!!
I remember seeing the engine run on the stand somehow......Maybe Mario posted it or something.
That must be quite the ride with turbo..........All you need is an intercooler and about 12 lbs. more boost..... :wink: :wink: 8)
Kidding...that thing probably hauls **s!!!!!
buguy
Post by buguy »
That's quite a parts list! Where abouts in Florida are you?
Bills914-4
Clonebug wrote: ↑Thu Apr 16, 2020 7:54 am Very Nice!!!!
Thank you , Mario set-up my Megasquirt2-Sequential fuel & Ign. ,then posted a video I sent him :) , I've seen the boost gauge
hit 12lbs. made me a little uneasy considering it has 10.7 c.r. , another time in beginning test run the hose was off the wastegate
(ran like a ) lets just say it scared me :shock: , before I realized the hose was off , I did a compression test right away afterwards
everything was good :roll: , thank God,
Bills914-4
buguy wrote: ↑Thu Apr 16, 2020 8:09 am That's quite a parts list! Where abouts in Florida are you?
Out West of Miami ( Hialeah Gardens ) It's good for test drives 8) , I got the turn pike for testing getting up to speed :twisted: ,
& I got Okeechobee Highway out by the Everglades :wink: , thats where I usually do the tuning ,
Bills914-4
More pictures
Bill DeWitt
2800cc 914-4
Weekend Therapy :D
buguy
Post by buguy »
Wow! Boost and 10.7:1 compression! That's nuts!
andy198712
Post by andy198712 »
E85 or not? nice exhaust! does the muffler work?
Bills914-4
More pictures
Bill DeWitt
2800cc 914-4
Weekend Therapy :D
Bills914-4
buguy wrote: ↑Thu Apr 16, 2020 10:13 am Wow! Boost and 10.7:1 compression! That's nuts!
I took one spring out of the wastegate theoretically it should be limited to about 7 lbs. I would think, I feel the programmable
water/meth is what helps it , along with twin plugs & 20 degrees max timing ?
snow performance stage 4
this system is programmable ,so I can add more here and their ? still learning as I go :)
Bill DeWitt
2800cc 914-4
Weekend Therapy :D
buguy
Post by buguy »
I'm interested. You might take top honors for compression/boost around here.
Clonebug
Post by Clonebug »
Did you buy a new baking pan or steal your wife's good one for the turbo cover???? :shock: :lol: 8)
What kind of intake temps are you seeing at cruise and when on boost???
Bills914-4
andy198712 wrote: ↑Thu Apr 16, 2020 10:17 am E85 or not? nice exhaust! does the muffler work?
No E85 yet ( there is a station 2 blocks from house that sells it :) ) , I'm building another motor 2.5 ( 80mm x 100mm) that I want
to run as much as 20 lbs boost :twisted: , it will probably run E85 ? & a intercooler , I'm off work because of covid-19 , so I started
working on it again ,
www.shoptalkforums.com/viewtopic.php?f=1&t=150581
the bullet muffler helps some , but I do need to quiet it some more , I towed (car dolly) it to N. Carolina last September to event
called Okteenerfest 914 gathering about 50 914 cars showed , we drove the back roads up their, one the of the guy's running behind me was telling me his wife thought my car was a little loud :) , we were running thru the twisties in the canyon , my car starts spooling around 3800 rpm ,between that and the little muffler, along with the 5800-6000 rpm gear changes , it might be a little loud following behind :lol: ,
Bills914-4
Clonebug wrote: ↑Thu Apr 16, 2020 11:14 am Did you buy a new baking pan or steal your wife's good one for the turbo cover???? :shock: :lol: 8)
I have to laugh also , she was throwing it out , I thought it was usable for the top of the bench to trow stuff in , so me being kind
of a hoarder :lol: , saved it , it was on the bench (full of stuff) when I was trying to come up with an idea on how to cover the
turbo , first thought was to bend up something , then I saw the pan :?: , :lol: , I have 2 coverings of thermal adhesive tape on the under side along with a heat shield between the exhaust and the trunk floor ,it was getting warm in the trunk , I also added 2 fans to exhaust the air out of the trunk , I also added one more nozzle smaller in the charge tube right after the turbo , to help with air temps , one of the fans has adjustable thermoswitch , I haven't seen the temps go over 130 , but I haven't driven it in the
Miami summer yet , we will see soon , the weather is already getting hot here , I haven't driven since before Chritsmas , I'm getting itchy to go for a drive ,
