Big valves
Schweg
Big valves
Post by Schweg »
Not sure this is right place for this, but here goes anyone know what the biggest valve you can put in a stock casting head is? I’m looking to replace seats as well.
66brm
Re: Big valves
Post by 66brm »
Depends on bore, a 42*37.5 will fit a 94 but not 85.5. To go larger with out issues irt longevity the guides need to be spread
Schweg
Re: Big valves
Post by Schweg »
Thanks!
So is it worth trying to fit larger calves in a stock head or just buy different castings?
That I guess is the second part of my question hearing that guides need to be moved.
Schweg
66brm
Re: Big valves
Post by 66brm »
How big are you looking to go? 90% of street engines have no need to go larger than 42mm intakes unless they see a lot of strip time. Add boost and the need for a larger valve is also reduced.
Schweg
Re: Big valves
Post by Schweg »
I’m really just trying to learn. I’m thinking a 40mm/37mm set up would be nice but as hard as I look I can’t seem to find out if there is enough material to do that.
I have a line on some used stock casting pretty much free that I am thinking about trying to build into 1915 turbo heads with a home port and polish. There is a local shop that will cut seats and do so guides for around $200.
Schweg
FJCamper
Re: Big valves
Post by FJCamper »
40x37 with moderate headwork will support up to 150hp no problem with the right cam and intakes if you keep it down to 6000-6500 range.
We usually run this valve combo on our Type 1 racing engines (LeMons endurance races) with great success. Once in a while we'll get a set of heads with 42mm intakes and bolt them on with our same usual carbs cams, etc., but notice no significent power difference.
FJC
Schweg
Re: Big valves
Post by Schweg »
Fj,
Thanks for the reply.
Are you doing that with a stock casting?
Schweg
FJCamper
Re: Big valves
Post by FJCamper »
044 casting.
Good luck.
