Distributor impulse buy
Gnasha
Post by Gnasha »
Hi, novice ACVW newbie here.
Building a 2056 T4 DTM plant for a 74 Karmann ghia. Twin Weber 40s, Scat C35, flyer transmission.
Bought a 021 905 205P dizzy on impulse, before thinking of its compatibility to the above. Its original fitment was stock with the type 4 2.0. However, will it still be compatible with the upgrades, especially its vacuum response?
Thanks for reading this.
wreck
Re: Distributor impulse buy
Post by wreck »
I've run a stock type 4 distributor on my 2300cc for years ,no issue . way better than a 009 it had for a while .
Gnasha
Post by Gnasha »
wreck wrote: ↑Mon Jun 22, 2020 3:35 pm I've run a stock type 4 distributor on my 2300cc for years ,no issue . way better than a 009 it had for a while .
Thats great news Thank you for your response wreck.
did you have a difficulty with the vacuum pulsing?
dstar5000
Post by dstar5000 »
Hook all 4 together in to one.....
Don
Wally
Post by Wally »
dstar5000 wrote: ↑Sat Aug 01, 2020 3:50 pm Hook all 4 together in to one.....
Don
Most 40 Webers don't have a ported vacuum connection (only some have a (usually fixed) pipe on some original (as used on OEM applications) italian Webers) and just sticking a pipe (or 4) into the manifold won't let the original vacuum canister work as it was supposed to be.
Just FYI :wink:
Eddie010
Post by Eddie010 »
I use the bus type 4 CU distributor, this is a hall sender transistor dizzy, so no points and very powerfull spark.(has a special coil)
Have not hooked the vacuum it has vacuum and weigth advance in them.
Running on 2.0L with 40 webers on them.
dstar5000
Post by dstar5000 »
Wally wrote: ↑Tue Sep 29, 2020 11:59 am
Don
Just FYI :wink:
HOOK ALL 4 CARBS TOGETHER....IF YOUR CARBS DONT HAVE THE NIPPLE, DRILL THEM AND STICK ONE IN THEM....
<3
DON
Some 60s-70s fords have a throttle operated valve that can provide "ported" vacuum from a manifold vacuum source.
the main thing required is having the advance shut off at idle so it doesnt idle at 2000 rpm.
