I have a 1974 Chenowth 2RL which I have taken to driving to work, and the carb life is getting old. Here is the subject of this academic pursuit:
First off, I ended up trading another member on here some 40x35 heads straight up for most of the Mexi EFI setup, which was great for the both of us considering our power targets and current build needs. So the parts collection begins!
-Mexi EFI throttle body, center intake section, end castings, and fuel delivery
-Microsquirt with latest firmware
-Mario's external crank trigger
-Mario's IGN-4VW coil with built in drivers to play nice with MicroSquirt
-Mario's GM calibration IAT
-Mario's rough head temp/warmup sensor
-VW VR6 Injectors, ~200cc/min, adequate for my unrealistic 120HP maximum possible believable output
-Custom Surge Tank to house a Bosch 040 In-tank high performance fuel pump
-Modified current RJS fuel cell for surge tank return
-UMP intake system utilizing their Solex airbox - a DEAD MATCH for the Mexi TB!
Let's begin! Parts stash accumulates....
Mario's crank trigger showed up, I didn't find it difficult to fit with the help of my 78 year old lathe.
Drilled and tapped and secured with awesome little 4-40 TORX drive screws from McMaster. (NOT pictured, I replaced them later)
Now it was time to retire to the CAD computer to plan my surge tank design and program the CNC machine to make it. I wanted to integrate the Bosch 040 pump instead of the wildly more popular "044" due to it's relative affordability, built-in intake filter screen, and more than adequate horsepower support for everything but the most radical air-cooled VWs.
While I was at it, I also laid out a control box of sorts to contain the MicroSquirt and fuses in a sealed environment. We have a laser cutter at work so I utilized that to cut the backplane to mount the components.
The actual making of the surge tank was, as you might guess, far more brutal than expected. The CNC part was easy, but making the surface finish of the pump mount bore adequate to seal and perfectly round required me to make it a little small on the CNC machine, and then bore it painstakingly at home on my manual mill.
I had to make a mount, which compared to the level of detail required on the surge tank, was sort of a side project.
Then I sent everything off for anodize, machined the shell tube on my lathe, honed it and assembled!
