Drill Press Accurately Centering the bit.
Posted: Tue Sep 22, 2020 9:19 pm
Previously the best results I had hand drilling a medium to large hole was to;
-Use a Automatic Center Punch
-Start a hole using a bit that the head of a Split Point drill bit would use as a guide
-Then finish with the Split Point bit.
I had to drill about 60 fairly accurate 3/8" holes and this method worked pretty well. I did have to re-do about 6 of them though.
I realize that there lots of different methods that people feel works the best like using a Starter Bit, drilling slowly and so forth. One of the methods I do not feel that works is to gradually step up with drill bit size. It just creates more instances for the bit to walk in my opion.
When I went shopping for a drill press I thought that a well fitting spindle would make the most accurate holes. I also knew that the brands that I could afford would have production tolerances that would change from product to product. Some of the models in stores had more play in the spindle but they all had some. I have read in forums that even the high priced machine shop models had loose fitting spindles. The Sears one averaged out in the decent range and had a bigger model with better features so I went with it. Plus, I wanted one last Sears purchase for nostalgia reasons.
My first assumption with using a Drill Press was that you could not drill a bad hole with them. I was wrong. The biggest issue I have had with using the tool that never drills a bad hole is trying to accurately position the bit where you want it. I did a pretty thorough internet search and the answer is to let the piece you are drilling float (not clamp it down), and let the bit find it's own center. I tried this by spinning the chuck backwards while slowly pressing the bit into the work. Afterwards I would use a clamp to hold it into that position. What I found was that if you pressed the bit into the guide hole the play in the spindle would allow the bit to move on a angle when entering the hole. So what I did was to use this principle to align the bit with the hole WHILE the work is camped down in a double cross vice. I positioned the point of the bit so that it would work like a ramp and force the bit to angle if not aligned and adjust one of the slides on the vice till the point of the bit would start into the hole without being forced in at an angle. Then II would spin the chuck 90 degrees and do the other. Lastly I would split between the two until the bit would go into the hole without being forced in at a angle. This method has been working well for me so I figured I would share it. Best of luck to you drilling your next hole. Lol.
