Performance FI intake for type-3?
Re: Performance FI intake for type-3?
I was thinking of running these on a 2270 I have planned, but don’t have the space in my early car. https://vwspeedshop.com/product.php?productid=16821
- Max Welton
Those are neat. Nice set of options and sizes.
Max
Max
Or if you’re on Instagram look up Jason Eggum. I believe he works for old speed, he could build you an intake set up
- Wally
Found this on FB:
Specifically for type 3 or so it read:
- Max Welton
Huh. I'm not on FB.
Details please!
Max
Details please!
Max
looks like drive by wire
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
- Chip Birks
OT
Do modern injectors fit in type3 EFI manifolds or do they need modifications? (Fuel rail required obviously but is the injector bore 14mm).
Thx
Thx
- Max Welton
First gen Ford Focus injectors fit if you remove the pintle cap.
https://www.thesamba.com/vw/forum/album ... ts=summary
Max
Max
- Wally
The original proper fit for 'modern' injectors is a little less then 14.0mm iirc, its 13.9mm I remember once measuring, but all stock type 3 or type 4 manifolds are much smaller. The fit of the O-rings you see in the pic from Max is where the O-ring sits on the tapered part. That works for N/A engines if your fuel rail pushes the injector hard enough in the curved recess of the stock manifold injector bore. If it also still works with boost depends on your boost level and how well your fuel rail is mounted I guess.
But to recap: no, the opening in stock type 3 mani's is NOT the same as modern injector holes. You can get by that however, as the factory did it the same way
T4T: 2,4ltr Type 4 Turbo engine, 10.58 1/4 mi
www.apfelbeck.nl
www.apfelbeck.nl
The vanagon/"T3" manifold and center plenum will literally bolt on a type 3 DP setup.(pancake t1 motor)
Port match will be way off...
The stock vanagon manifold end castings are steel or iron, so you have several choices how to reshape the transition for port match.
I have a setup if you wnt pics of how the plenum sits on the case. It should clear.
I may even have enough t1 parts to put together a mockup t3, although the t3 cooling system and HX went to a new home...
86+ wasserboxers were 2110s with ~web86 valve timing and dual springs, the high compression Euro DJs were rated at 112HP.
