71 Baja build
71 Baja build
Started on this thing last weekend. Got the main cage done. Alot more to tie into it. Getting the front ready to be chopped off. Ste of 5X5's on standby and put in a good size order for the front end. Hope to be back on it shortly after the new year.
- chuckput
Re: 71 Baja build
What are your plans for the front suspension?
- chuckput
Re: 71 Baja build
Are you going to tie the new beam into your roll cage, then?
Re: 71 Baja build
Yes. Will be making some type of a bulkhead and tying this into it. Cage bars will be welded into setup. Think shock towers may be getting removed and mounts be made into the cage. Its still up in the air. Just cut off some flanges and rewelded some spots that werent welded completely.
- chuckput
Re: 71 Baja build
Looks like you have a great plan and a great start. Looking forward to watching your progress here on STF.
- woodsbuggy1
Re: 71 Baja build
Looking good, hope you plan to remove rack mout so it can be installed with minimum bump steer. I could never understand why front beams come with rack mount installed, no way to know where rack needs to be mounted until you cycle suspension and find the sweet spot.
Kenric
Kenric
- Skidmark
Re: 71 Baja build
Did you lift the body to get 100% welds around your cage tubes?
"Your car sounds angry, and it wants to go fast all the time..."
(quote from my daughter, after driving my car)
It's not complicated, it's just expensive...
Re: 71 Baja build
Ah, the old "hot rod" way of doing it. It works and does make life easier as long as there isn't too much other stuff going on. Looks pretty nice!
Re: 71 Baja build
Yea, We did the same to a buddies car years ago. Works great.Ol'fogasaurus wrote: ↑Wed Dec 23, 2020 2:18 pmAh, the old "hot rod" way of doing it. It works and does make life easier as long as there isn't too much other stuff going on. Looks pretty nice!
Re: 71 Baja build
Got the front end on last weekend.
- Skidmark
Re: 71 Baja build
Your weld quality looks good!
Re: 71 Baja build
After a lot of arguing with myself: you might want to look into adding a cross-piece where the uprights between the upper and lower tubes are just to be sure the upper tubes (they are long) don't want bend at the upper bend in the tube as it goes into the body in some potential load conditions.
Re: 71 Baja build
Yea, it will be braced. Going to mount gas tank up there.Ol'fogasaurus wrote: ↑Mon Jan 25, 2021 12:18 pm beam support copy.jpg
That is more or less what I am trying to come up with but I have more restrictions and am dealing with fiberglass.
