New Parts For 2021
cal 67
New Parts For 2021
Post by cal 67 »
I'm getting more into importing and dealing high quality Type 4 parts lately, and these are some of my newest items:
True Type 4 diameter drop-in HD spring sets with titanium retainers, and dual sets that require boss narrowing. The retainers fit stock locks.
Outer: 34mm O.D., 25mm I.D.
Inner: 23.5mm O.D., 17.7mm I.D.
Pressures:
Single Dual
1.550" install: 121lbs 143 lbs
1.050" (.500" lift) 245 lbs 306 lbs
.950" (.600") 303 lbs 368 lbs
At 245, the singles should handle most applications up to 6,000 rpm.
And billet CNC oil pumps:
Arnoud
Re: New Parts For 2021
Post by Arnoud »
Hi!
I'm using the same oilpump:nice part.Never seen those retainers though.Titanium:nice!
Cheers,Arnoud
H2OSB
Post by H2OSB »
Tabari, I hope you become a major source for T4 parts. It's about time someone started catering to the T4 community in this way.
H2OSB
cal 67
Post by cal 67 »
H2OSB wrote: ↑Mon Feb 08, 2021 11:28 am Tabari, I hope you become a major source for T4 parts. It's about time someone started catering to the T4 community in this way.
H2OSB
I may end up there. For now, I supply a decent amount to keep me busy.
cal 67
Post by cal 67 »
Arnoud wrote: ↑Mon Feb 08, 2021 11:11 am Hi!
Cheers,Arnoud
The springs and retainers are unique. They're pretty cool. It's nice to know some guys have stepped up to make some nice items.
Eddie010
Post by Eddie010 »
I also have that oil pump, is yours 30mm or 24mm
cal 67
Post by cal 67 »
Eddie010 wrote: ↑Mon Feb 08, 2021 11:03 pm I also have that oil pump, is yours 30mm or 24mm
These are 30s
