Fellas,
is there any part numbers on a type 4 crank to quickly identify it? To tell if it's a 1.7/1.8 or a 2.0?
Crank identification
Eddie010
Re: Crank identification
Hi,
1.7 and 1.8 are the same, 66 mm stroke and the rod journal diameter of those cranks are 55mm.
2.0 are 71mm stroke and have a rod journal diameter of 50mm, that is the difference.
( as a matter of facts all cranks are the same the 2.0 is a turn down version of the 1.7/1.8 by turning down the rod journal from 55 to 50
they gained the extra stroke )
- craigvwdude
Thanks for the info!
Ya I knew the stroke difference, but couldn't remember the journal diameter.
Getting old sucks! LOL
- dstar5000
YEP!
DON
DON
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
- VIPERGREEN76
Great info.Eddie010 wrote: ↑Sun Feb 28, 2021 10:23 pm Hi,
76 SEDAN
EC type 4 Conversion project
Eddie010
If I have it correctly those are:VIPERGREEN76 wrote: ↑Sun Mar 07, 2021 8:04 amGreat info.Eddie010 wrote: ↑Sun Feb 28, 2021 10:23 pm Hi,
they gained the extra stroke )How about the rods length?
1.7/1.8 Rods are 127mm (55mm rod journal / 24mm piston pin)
2.0 are 131mm (50mm rod journal / 24mm piston pin).
- VIPERGREEN76
