As the search function doesn't let you look for 3 letter searches I'm not sure how to find these if they exist....
Does anyone have CAD files for Adjustable spring plates & a split Type2 chassis section, torsion housing rearwards.
I've found a rear section of a Type 1 chassis & SA spring plates, but I really need adjustable springs plate & a bus rear chassis CAD file for some design work I'm tinkering with.
CAD files?
- Jadewombat
Re: CAD files?
CAD file would just cut the plates, not the splined portion, correct? Would you transfer the splined section over from another? Which torsion bars are you using? I did a bay T2 IRS swap into my bus years ago (I think it was Wolfgang?) but the torsion bars were early bay I think and late bay trailing arms, don't remember.
Just a thought, why not just reindex the torsion bars close to the height you need, then take up the rest with adjustable coiloves? There's a huge selection of adjustable coilovers nowadays compared to the cheap EMPI crap we were stuck with for so many years.
- vwjim
Re: CAD files?
Hi,
I'm not trying to make the spring plates, just want to build a CAD model of the rear of a Split with Type1 adjustable spring plates.
- panel
Re: CAD files?
