Need Help Measuring a Type 4 Case / Mains
Posted: Thu Jul 22, 2021 5:19 pm
Hi All,
I'm waiting on my heads and barrels to be machined and have stripped my case, got it all cleaned up nice and put it back together then torqued the main cap nuts and setup a bore gauge to measure the main bearings. Issue I'm having is I can't get a consistent reading on them. I did the light check from the back on the centre main and if you're really fussy you can see a small dot of a shimmer. What I don't make sense of is they seem very out of round in an inconsistent way and worse on the outer ones. I think the case is misaligned and the crank / bearings play a role in aligning it. Should i have the cam and bearings in at this point to help on that side? At the moment I can feel a light ridge between the case halves at the bearings with my nail and it measures similar to if you have a rod cap on the wrong way around. With a gauge in some points its spot on but some are up to .10mm over and some points seem under size. Centre bearing measures the best which I thought from what I 've read was the one to watch for.
I'm not expecting the case to be too bad as its had a rebuild at some point and the bearings were in good shape. Crank measures up stock and the bearing were std/std also.
Can someone who has done this a few times give me a rundown of how you measure the mains or point me to a thread that covers it? I couldn't find one when using the search.
If you want anymore info let me know.
Thanks,
Patrick
Thanks,
Patrick
