DIY or maching shop dimpled or crosshatched/slotted rotors ?
- panel
Anyone have a machine shop dimple and/or crosshatch/slotted your rotors ? Not cross drilled !
Ian Godfrey
Re: DIY or maching shop dimpled or crosshatched/slotted rotors ?
Yes, but in Australia not USA , sorry.
I got slot and dimple, very happy. Little bit more pad wear but it really grips.
hopefully some one local to you can help
Ian
Ian
- slayer61
The guys at TrueDisc come highly recommended in the motorcycle world. They might be able to do bug stuff
https://truedisk.net/
- panel
I have access to a machine shop so this part is taken care of
It's the pattern and depth etc. Is there a dimple 3-2-3-2 sorta pattern ? And if I decide on the slotted.....wonder if the curve should be a certain radius ?
Ian Godfrey
here's some nice patterns you could copy. My dimples are 2 mm deep
https://www.adamsrotors.com/custom-dimp ... otors.html
