Looking for 1.7 litre 90 mm Pistons
Posted: Thu Aug 12, 2021 8:58 pm
Maybe you have missed these tricks of Leatherman Wave Multitool
Leatherman wave has been the best multi-tool brand on the market for years. When you say you have the best rated multi tools in your pocket, we would think of the Leatherman wave multifunction tool sitting comfortably in your pocket. No matter how long you have been using this high-quality multi-tool for your daily tasks, we bet that most of us didn’t bring out the best of our multi-tool since besides from multiple tools included inside the pliers handle of Leatherman wave multi-tool. There are those accessories that are hidden tricks that you wish you would know sooner. Don’t worry. We would expose them all below.
Maintain your tool properly
This might sound boring, but it is true that if you don’t maintain your high-quality tool properly, all the tips and tricks are just a bunch of clichés. So, what does maintain properly mean? The first and easiest stage of maintaining should be cleaning the tool right after using it. We know that to most of us, the Leatherman Wave is an everyday carry tool. We seek its help more than ten times a day, that’s why we should keep it clean and nice. The second maintaining stage must be lubricating your tool with the right oil to maintain its long-lasting performance. We all want our Leatherman to have a perfect snick sound when the tools are set in place and the smooth operating afterward; hence, this tip is essential before moving to any other pieces of advice.
The lanyard eye
Have you ever thought that it would be nice to find somewhere on your good multi-tool to loop a short wire and hang it up? But that ‘somewhere’ is nowhere to be found on your beloved Leatherman. You might wonder that maybe the manufacturer forgot to put the lanyard eye in their all-in-one multi-tool. The answer is they didn’t. But it would take a little effort to bring out the Leatherman’s lanyard eye. You need the screw bit from the bit holder to push out the saw, and the lanyard eye is right under it. Now, you can loop the wire through the lanyard eye, hang the Leatherman on your wrist, your ladder, or anywhere that is comfortable for you to reach while working with your multi-tool.
Make good use of the serrated blade
You might think this is another boring tip, but it is essential to use the right tool for the right task. We know the Leatherman is equipped with different knife blades, and each one has various functions as well. Not all the TOP 10 multi tools on the market now has the serrated blade hidden in its plier handles as Leatherman has. Therefore, your multi-tool has it; why don’t you use it? The serrated blade is made for dealing with those cardboard and plastic packaging of your delivery. If you use the main blade for these kinds of material, the abrasives contained in the cardboard and packaging traps are quickly making your knife dull. Hence, give your main blade a break and use the serrated blade instead. In this way, your multi-tool is working more efficiently and saves you a lot of strength with the cutting delivery package task.
With the best multitool in your pocket, we believe that these ideas would help you to bring out the best of it. Please keep in mind that, no matter what you do with your multi-tool, maintaining it after every time you use it is important. Maintaining your Leatherman wave properly and all these tips will improve your equipment working efficiency.
The lanyard eye
